DAC output not working
danieloneill9
Posted on September 05, 2012 at 04:38
Hi All,
I had the DAC working using DMA to out put a sinewave continuously and it seems to have stopped working when I tried to change which timer I triggered off. After changing the timer configuration back it still doesn't work.
I believe I configure everything I need to and I have code that read DAC->DOR1 out via the USART and it shows this data updating as I expect but I don't see any voltage on the DAC pin.
Any ideas?
Daniel
#dac
12 REPLIES 12
Posted on September 05, 2012 at 05:13
Sounds like a pin configuration or VDDA issue.
What part are we talking about?
What does the pin config code look like?
danieloneill9
Posted on September 06, 2012 at 08:05
Hi Clive,
The part is a STM32F103.
The pin config code is as follows:
  GPIO_InitTypeDef GPIO_InitStructure = {
      GPIO_Pin_4,
      GPIO_Speed_50MHz,
      GPIO_Mode_AIN
  GPIO_Init(GPIOA, &GPIO_InitStructure);
Cheers,
Daniel
szbrozek9
Posted on September 06, 2012 at 08:53
I noticed that you didn't use the GPIO configuration system in the canonical way, but checking the GPIO_InitStruct suggests that what you did should work. Quick overall DAC checklist:
Did you turn on the DAC and GPIO clocks before configuring the peripherals:
RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
Did you configure the DAC:
DAC_InitStructure.DAC_Trigger = DAC_Trigger_Software;
DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;
DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Enable;
DAC_Init(DAC_Channel_1, &DAC_InitStructure);
DAC_Cmd(DAC_Channel_1, ENABLE);
Did you actually write something to the DAC:
DAC_SetChannel1Data(DAC_Align_12b_R, 0x07FF);
DAC_SoftwareTriggerCmd(DAC_Channel_1, ENABLE);
danieloneill9
Posted on September 06, 2012 at 09:31
clocks
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA2, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO, ENABLE);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
DAC
  DAC_InitTypeDef DAC_InitStructure = {
    DAC_Trigger_T4_TRGO,              /*DAC_Trigger*/
    DAC_WaveGeneration_None,          /*DAC_WaveGeneration*/
    DAC_LFSRUnmask_Bit0,              /*DAC_LFSRUnmask_TriangleAmplitude*/
    DAC_OutputBuffer_Disable         /*DAC_OutputBuffer*/
I have a DMA loop that writes to the DAC. When I poll the DAC->DOR1 register I see data in there changing as I expect.
szbrozek9
Posted on September 06, 2012 at 09:44
szbrozek9
Posted on September 06, 2012 at 09:45
szbrozek9
Posted on September 06, 2012 at 09:46
danieloneill9
Posted on September 06, 2012 at 12:21
Hi All,
A poke round and a clean build later and the DAC is working.....
Thanks for the help.
Cheers,
Daniel
megapin
Posted on January 29, 2013 at 19:53
Hi!
board: STM32VL Discovery
DAC1,DAC2 DORx Register = 0;
Why out voltage = 60 mV?
