Cycle count of 32x32 multiplication on STM32F072?
‎2021-01-20 8:53 AM
The technical docs state that multipleication (MULS instruction) can take either 1 cycle or 32 cycles. This is defined when the board is produced. Does anyone know which of the two configurations the STM32F072RB uses?
Documentation
STM32F0 Series
‎2021-01-20 9:16 AM
That sounds like complete nonsense, can you provide an actual cite?
Do you mean what ARM IP ST chose to include in their Cortex-M0 chip level implementation?
As far as I'm aware ST chose to have the multiplier, systick and debug functionality. "Single-cycle 32-bit hardware multiplier"
Should be easy enough to measure ones' self if there is any doubt.
‎2021-01-20 9:16 AM
‎2021-01-20 10:08 AM
Thank you.
