CubeMx User-Labels starting with digits will fail compilation
taraben
Posted on February 10, 2016 at 18:49
Dear ST,
CubeMx lets me enter user labels. Which is a good feature.
However Label starting with digits will fail in compilation proccess.
In my case I put ''12V_SENSE'' as on the schematic program.
Please check User Labels to match ''C'' convention for variables names.
Or generate a proper sequence. (i.e. putting undeline before - I don't know if this breaks C conventions)
Regards, Adib.
#!stm32-!cubemx
Andrei Chichak
Lead II
Posted on February 10, 2016 at 21:48
Yes, this has been the case with C identifiers since about 1972.
You COULD change your identifier to V12_SENSE or _12V_SENSE or even _12, and all of those would compile.
Andrei from The Great White North
taraben
Posted on February 10, 2016 at 23:17
Hello Andrei,
yes I know I am able to change.
But as CubeMx is the Codegenerator for C-Code it must repect that limitation in one or the other way.
Either restrict the user or find a way around.
FYI if you put a space or slash it will be replaced by underline.
So, for me this is clearly a limitation. Call it a bug.
Adib.
