MGado.1
Visitor II
Creating delay using __asm__("nop")
How to measure the time from __asm__("nop") on STM32F730 using 216 MHz clock? I did try to check it using osciloscope without success. The time is bigger than 1/216 MHz.
DWT->CYCCNT will measure ticks. You'll need to figure out and subtract off the overhead for accessing it.
https://community.arm.com/developer/ip-products/processors/f/cortex-m-forum/8952/where-to-find-the-execution-cycles-of-cortex-m7-instruction
The Cortex-M7 pipeline is not as straightforward as it is for Cortex-M4. NOP instruction isn't guaranteed to take any time at all.
Tesla DeLorean
Guru
Why would you do it this way? Seems highly prone to caching and superscalar issues, not to mention interrupts.
Can't you use a 32-bit TIM to account for passage of time, or use the DWT_CYCCNT to count cycles?
Tesla DeLorean
Guru
volatile unsigned int *DWT_CYCCNT = (volatile unsigned int *)0xE0001004; //address of the register
volatile unsigned int *DWT_CONTROL = (volatile unsigned int *)0xE0001000; //address of the register
volatile unsigned int *DWT_LAR  = (volatile unsigned int *)0xE0001FB0; //address of the register
volatile unsigned int *SCB_DEMCR = (volatile unsigned int *)0xE000EDFC; //address of the register
 *SCB_DEMCR |= 0x01000000;
 *DWT_LAR = 0xC5ACCE55; // unlock
 *DWT_CYCCNT = 0; // reset the counter
 *DWT_CONTROL |= 1 ; // enable the counter
uint32_t start, finish, delta;
start = *DWT_CYCCNT;
finish = *DWT_CYCCNT;
delta = (finish - start);
