Contents of the unique device ID registers LOT_NUM
I'm using STM32L031E6Y6 for a high volume low cost product and I'm hoping to arrange it so that even if my firmware binary were to be stolen, it could only be used to produce a limited number of counterfeit products.
I can cryptographically fix the firmware so that it will only run if the LOT_NUM part of the device ID registers is within a certain range but how many unique devices might share the same lot number ?
Also, is it probable that all the devices on a reel share the same lot number and is it possible to discover the lot number(s) before flashing the devices ?
