ted korczak
Code translation
  • June 11, 2018
  • 4 replies
  • 1229 views
Posted on June 11, 2018 at 08:37
Hi
How to change arduino uno code to STM32F103
void setup(){ pinMode(9,OUTPUT); pinMode(10,OUTPUT); TCCR1B = (1<<WGM13)|(1<<CS10);  TCCR1A = (1<<COM1A1)|(1<<COM1B1)|(1<<COM1B0);  TIMSK1 = 1<<TOIE1; ICR1=511;  OCR1B=0; }   ISR (TIMER1_OVF_vect) { static uint8_t  n=0; OCR1A =  OCR1B= sine_wave[n]; n++; }  void loop(){ }
    Best answer by henry.dick
    Posted on June 11, 2018 at 20:09
    Don't look at individual lines of code but blocks of code and ask yourself what those blocks are trying to do.
    After that implement the functionality on your new target.
    Tesla DeLorean
    Guru
    June 11, 2018
    Posted on June 11, 2018 at 20:06
    You'd be better starting with what you're trying to achieve, and re-implement.
    Set up clocks and pins
    Program periodicity of TIM
    Set up circular DMA to point to Sine Wave table, and configure TIM/DMA to update pulse width at each period update.
    henry.dick
    henry.dickBest answer
    ted korczak
    Posted on June 11, 2018 at 22:25
    I am trying to modify simple sine wave generator for stm32f103, post # 21, click on - показать код
    http://arduino.ru/forum/programmirovanie/shim-sinusoida#comment-152231
    ted korczak
    Posted on June 12, 2018 at 05:25
    How to do that some links will help.
    Similar code for STM32
    HardwareTimer pwmtimer2(2); void setup() { pinMode(PA3, PWM); //Pin mode selected pwmtimer2.pause(); pwmtimer2.setPrescaleFactor(1); // Prescaler setup pwmtimer2.setOverflow(10000-1); // 256 ? pwmtimer2.setCompare(TIMER_CH4, 5000); // ? pwmtimer2.refresh(); pwmtimer2.resume(); } void loop() { } // How to tell to produce sine ?
