clock change
raji a
Posted on August 07, 2017 at 15:08
Hit
    I am Using STM32L0 Discovery board, i want to switching the clock configuration from HSI to MSI and Vice vesa in my application .
For LowPower run  Mode ,i need MSI clock .During Startup ,Sleep Mode ,and after LowPower run Mode i need to switch From MSI to HSI clock .
Please Help me how to do this .
#clock-configuration
Posted on August 07, 2017 at 18:38
Using what library?
Review SystemClock_Config() code. Use of HAL_RCC_OscConfig() and HAL_RCC_ClockConfig()
Libraries typically have multiple examples, and use-case demonstrations. Review those.
Posted on August 08, 2017 at 07:19
Thanks for your reply . pLEASE find my sysclock_config() below
 __HAL_RCC_PWR_CLK_ENABLE();
 __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
 RCC_OscInitStruct.HSICalibrationValue = 16;
