Choose a 12 MHz crystal to the STM32F405 from JLCPCB basic parts?
Hello, I'm designing a new Board base on the STM32F405RGT and i want to use a 12MHz crystal from JLCPCB with this references C9002 Yangxing Tech|Yangxing Tech X322512MSB4SI|SMD Crystal Resonators|LCSC.
Is this crystal a 20pf? and did any one use it before, please if any one had use it in his board help me with a feedback about this component>
Peter BENSCH
Hi and welcome to the community!
Please take a look into the application note AN2867 - Oscillator Design Guide for ST MCUs, which is important to understand how to choose a crystal, how to calculate the load capacitors and the recommendation for layout.
For the HSE you can look directly into section 4.2, for the layout please read section 7.
Good luck!
/Peter
Peter BENSCH
Good luck!
/Peter
