markkonnov
Check CAN on single nucleo F103
  • June 2, 2016
  • 745 views
Posted on June 02, 2016 at 08:24
Hi everyone.
I see CAN TX interrups.
I can't catch interrupt related to CAN RX just by putting jumper between PB8 and PB9 (GPIOs are remapped - double checked).
Is it possible ?
#bxcan #nucleo103rb #stm32 #can
Tesla DeLorean
Guru
June 2, 2016
Posted on June 02, 2016 at 18:33
You'd need some else on the bus to acknowledge. Suggest you use loopback mode for this type of testing.
markkonnov
Posted on June 02, 2016 at 22:59
In loopback I'm failing into interrupts and everything OK.
But you did clarify a lot. Thanx !
