2016-06-01 11:24 PM
Hi everyone.
I see CAN TX interrups.I can't catch interrupt related to CAN RX just by putting jumper between PB8 and PB9 (GPIOs are remapped - double checked).Is it possible ? #bxcan #nucleo103rb #stm32 #can2016-06-02 09:33 AM
You'd need some else on the bus to acknowledge. Suggest you use loopback mode for this type of testing.
2016-06-02 01:59 PM
In loopback I'm failing into interrupts and everything OK.
But you did clarify a lot. Thanx !
