Can we distinguish which ADC channel has done the conversion when using multichannel interrupt method ADC??
STee.3
FBL
Hello @Community member​
It is possible to determine which channel has completed the conversion. When ADC generates an interrupt, you can determine which channel has generated it.
Which STM32 product you are using?
Best regards,
FBL
STee.3
STM32L4
waclawek.jan
Not directly.
It's your program, you know how many channels did you put into a sequence and when did you start the sequence, so simply count the interrupts.
Announcement
