Can ST8500 MCU support communication through DC lines? The Voltage of the DC lines will be around 5-20V.
jsrin.1733
5 REPLIES 5
Ozone
Lead II
How about checking the datasheet: https://www.st.com/resource/en/datasheet/st8500.pdf ?
jsrin.1733
Ya I have checked but it lacks clarity.They haven't directly mentioned it supports communication through DC line.
DC to 500 KHz​
Probably would have lead​ with something clearer in front page bullets.
Thank you. I did see that. DC with what voltage???
Would suggest you talk with an FAE supporting the Power Line Comms products.
I'd presume it would connect via a DC blocking capacitor. The ADC has a 1.8V p-p range
