Can I set the heap size to zero?
Lars Beiderbecke
Senior III
In my STM32F72xx/3xx project, I'm not allocating memory dynamically, i.e., I'm using neither malloc nor free. And I'm restricting myself to C, with no C++ parts.
Is there a reason I shouldn't set the heap size to zero? Do any of the drivers, HAL or CMSIS, or FatFs, rely on the heap?
FatFs, depends on the configuration, LFN support can use malloc/free.
Some of ST's USB code uses malloc/free
Piranha
Chief II
Yes, You can and should do it. That is the only way how I make my projects and my projects do work. As far as I know (but can not guarantee) HAL doesn't use heap, though I do not use HAL anymore. Can't comment on FatFs.
What exactly do You mean by CMSIS? It has many different parts!
Pavel A.
To be sure, fill the heap with some pattern before running your stuff, later check if it has (not) changed.
-- pa
