Can-Bus Error
muhammet
Posted on May 12, 2014 at 19:56
The original post was too long to process during our migration. Please click on the attachment to read the original post.
26 REPLIES 26
Posted on May 13, 2014 at 19:18
For the F2/F4 I had
CanTxMsg TxMessage;
volatile uint32_t i = 0;
uint8_t TransmitMailbox = 0;
TransmitMailbox = CAN_Transmit(CAN1, &TxMessage);
i = 0;
while((CAN_TransmitStatus(CAN1, TransmitMailbox) != CANTXOK) && (i != 0xFFFFFF)) // Wait on Transmit
i++;
muhammet
Posted on May 13, 2014 at 19:19
Clive1 do you see any mistake my code?
Posted on May 13, 2014 at 19:35
Well, I'm pretty sure your APB clock is NOT 30 MHz, and the CAN baud is not 1 Mbps. Those seem like STM32F2 numbers for 120 MHz CPU, and APB1 at DIV4, not an STM32F4 at 168 MHz
muhammet
Posted on May 13, 2014 at 19:49
I has STM32F4 Discovery Kit , It has a Stm32f407VG6 chip. How to configure clock and baud rate. When I read value from the beaglebone black I write
sudo ip link set can0 up type can bitrate 1000000
Posted on May 13, 2014 at 21:21
Try this, I'd perhaps have used 125 kbps
// STM32F4 CAN1 TX Loop, requires RX Node, CPU @168MHz APB1 @42MHz - sourcer32@gmail.com
#include ''stm32f4xx.h''
int main(void)
RCC_ClocksTypeDef RCC_Clocks;
CAN_InitTypeDef CAN_InitStructure;
CAN_FilterInitTypeDef CAN_FilterInitStructure;
CanTxMsg TxMessage;
RCC_GetClocksFreq(&RCC_Clocks);
/* CAN GPIOs configuration **************************************************/
/* Enable GPIO clock */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE);
/* Connect CAN pins */
GPIO_PinAFConfig(GPIOD, GPIO_PinSource0, GPIO_AF_CAN1);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource1, GPIO_AF_CAN1);
/* Configure CAN RX and TX pins */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
GPIO_Init(GPIOD, &GPIO_InitStructure);
/* CAN configuration ********************************************************/
/* Enable CAN clock */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);
/* CAN register init */
CAN_DeInit(CAN1);
CAN_StructInit(&CAN_InitStructure);
/* CAN cell init */
CAN_InitStructure.CAN_TTCM = DISABLE;
CAN_InitStructure.CAN_ABOM = DISABLE;
CAN_InitStructure.CAN_AWUM = DISABLE;
CAN_InitStructure.CAN_NART = DISABLE;
CAN_InitStructure.CAN_RFLM = DISABLE;
CAN_InitStructure.CAN_TXFP = DISABLE;
CAN_InitStructure.CAN_Mode = CAN_Mode_Normal;
/* quanta 1+6+7 = 14, 14 * 3 = 42, 42000000 / 42 = 1000000 */
/* CAN Baudrate = 1Mbps (CAN clocked at 42 MHz) Prescale = 3 */
/* Requires a clock with integer division into APB clock */
CAN_InitStructure.CAN_SJW = CAN_SJW_1tq; // 1+6+7 = 14, 1+14+6 = 21, 1+15+5 = 21
CAN_InitStructure.CAN_BS1 = CAN_BS1_6tq;
CAN_InitStructure.CAN_BS2 = CAN_BS2_7tq;
CAN_InitStructure.CAN_Prescaler = RCC_Clocks.PCLK1_Frequency / (14 * 1000000); // quanta by baudrate
CAN_Init(CAN1, &CAN_InitStructure);
/* CAN filter init */
CAN_FilterInitStructure.CAN_FilterNumber = 0; // CAN1 [ 0..13]
CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask; // IdMask or IdList
CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_32bit; // 16 or 32
CAN_FilterInitStructure.CAN_FilterIdHigh = 0x0000; // Everything, otherwise 11-bit in top bits
CAN_FilterInitStructure.CAN_FilterIdLow = 0x0000;
CAN_FilterInitStructure.CAN_FilterMaskIdHigh = 0x0000;
CAN_FilterInitStructure.CAN_FilterMaskIdLow = 0x0000;
CAN_FilterInitStructure.CAN_FilterFIFOAssignment = CAN_FIFO0; // Rx
CAN_FilterInitStructure.CAN_FilterActivation = ENABLE;
CAN_FilterInit(&CAN_FilterInitStructure);
// transmit */
TxMessage.StdId = 0x123;
TxMessage.ExtId = 0x00;
TxMessage.RTR = CAN_RTR_DATA;
TxMessage.IDE = CAN_ID_STD;
TxMessage.DLC = 8;
TxMessage.Data[0] = 0x02;
TxMessage.Data[1] = 0x11;
TxMessage.Data[2] = 0x11;
TxMessage.Data[3] = 0x11;
while(1) // Do not want to exit
volatile uint32_t i;
static int j = 0;
TxMessage.Data[4] = (j >> 0) & 0xFF; // Cycling
TxMessage.Data[5] = (j >> 8) & 0xFF;
TxMessage.Data[6] = (j >> 16) & 0xFF;
TxMessage.Data[7] = (j >> 24) & 0xFF;
j++;
i = 0;
i++;
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf(''Wrong parameters value: file %s on line %d
'', file, line) */
/* Infinite loop */
while (1)
#endif
muhammet
Posted on May 14, 2014 at 14:14
Thank you for help. When I look to oscilloscope I can not see anything. I don't know why I can not see data.
Posted on May 14, 2014 at 14:33
PD0/1 or PB8/9?
muhammet
Posted on May 14, 2014 at 14:39
PDO and PD1
Posted on May 14, 2014 at 21:00
PD0/1 look to be clear on the STM32F4-DISCO, perhaps you can diagram your circuit for review. Check you don't have RX/TX switched.I'm using PD0/1 on an
https://community.st.com/0D50X00009XkhqnSAB
STM32F2 design with code that's materially similar to this, I have GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL, and use a different transceiver with an external enable pin.
Edit: Fixed DEADLINK, original post from 14-May-2014
muhammet
Posted on May 14, 2014 at 22:29
What do you think about the code. Are sure that code is true. Can you try or look this?
And I use keil ide. Can I see that the data is send without using the oscilloscope.
