C Plus Plus
greg_t
Posted on August 06, 2011 at 09:11
&sharpifdef __cplusplus
extern ''C'' {
&sharpendif
I've seen the above in all the library header files , but what does it mean?
#mix-c-and-c++
donald2
Posted on August 06, 2011 at 13:21
It allows the header file to be used with either 'C' or C++ compilers.  You can ignore it.
Andrew Neil
Posted on August 06, 2011 at 20:00
http://www.parashift.com/c++-faq-lite/mixing-c-and-cpp.html#faq-32.2
