Bug in HAL library (HAL_RTCEx_SetWakeUpTimer_IT)
Posted on August 01, 2015 at 18:18
*Bug: HAL_RTC weakup does not interrupt
*Reason:
The library stm32f4xx_hal_rtc_ex.h missing to clear the interrupt flag before enabling the interrupt*Solution:
Manually add this line (clear the interrupt flag): /* Clear the Flags in the RTC_ISR register */ RTC->ISR = (uint32_t)((uint32_t)(~((RTC_FLAG_WUTF | RTC_ISR_INIT)& 0x0000FFFF) | (uint32_t)(RTC->ISR & RTC_ISR_INIT)));before the /* RTC WakeUpTimer Interrupt Configuration: EXTI configuration */ line*ST please fix file:@file stm32f4xx_hal_rtc_ex.c * @author MCD Application Team * @version V1.3.2 * @date 26-June-2015 #bug-rtc-weakup-interrupt
