Bug in HAL library (HAL_RTCEx_SetWakeUpTimer_IT)
smhhadima
Posted on August 01, 2015 at 18:18
*Bug: HAL_RTC weakup does not interrupt
*Reason:
 The library  stm32f4xx_hal_rtc_ex.h  missing to clear the interrupt flag before enabling the interrupt
*Solution:
Manually add this line (clear the interrupt flag):
 /* Clear the Flags in the RTC_ISR register */
    RTC->ISR = (uint32_t)((uint32_t)(~((RTC_FLAG_WUTF | RTC_ISR_INIT)& 0x0000FFFF) | (uint32_t)(RTC->ISR & RTC_ISR_INIT)));
before  the /* RTC WakeUpTimer Interrupt Configuration: EXTI configuration */ line
*ST please fix file:
@file    stm32f4xx_hal_rtc_ex.c
  * @author  MCD Application Team
  * @version V1.3.2
  * @date    26-June-2015
#bug-rtc-weakup-interrupt
1 REPLY 1
Nesrine M_O
Lead II
Posted on August 06, 2015 at 15:10
Hi SamTheMan,
Thank you for your feedback. The issue has been reported internally.
-Syrine-
