Broken Project from cube v 4.24.0
beomki cho
Posted on January 31, 2018 at 01:46
so, i've updated cube to v4.24.0
and it starts to make broken .ioc files
i tried several ways to reproduce same issue and here's the problem.
1. make a project with stm32f407ze ( not sure it's because of this but.. )
2. make CAN1 and CAN2 as master mode and slave mode.
3. go to configuration and open up CAN1 setting
4. make Time quanta BS 2 as 7
5. make prescaler to 4
6. make Time quanta BS 1 as 10
7. press okay and save project.
( at this point, you can't open up CAN1 configuration window )
8. and now project is unreadable
my solution to fix this is to manually modify ioc file, removes CAN related configuration
Imen.D
Posted on February 01, 2018 at 12:00
Hello
joebk
We raised this issue internally to CubeMX team.
Thank you for highlighting it, and Sorry for the inconvenience it may bring.
Best Regards,
Imen.
Imen
Imen.D
Posted on February 01, 2018 at 15:02
Hi
joebk
You are right, we can reproduce the same behavior.
This issue will be fixed next release.
Best Regards,
Imen.
Imen
stm32cube-t
Posted on February 21, 2018 at 10:27
Sorry for the inconvenience. This problem will be solved in next STM32CubeMX 4.25 release coming out in few weeks from now.
