Broken Forum Login
Posted on May 18, 2016 at 20:54
The forum has been a mess the last few days. Only ''sign-on to forum'' seems to work, entering username/password on message replies just results in all sorts of error screens/pages. TCP connect or somesuch.
#worst-forum-software-ever #worst-forum-software-ever
Posted on May 24, 2016 at 17:43
The empty XML was a random response from the server during one login attempt. The sign in sometimes requires two attempts, ie you submit once, and the same login comes back again.
Still habitually seeing this if attempting to reply to a post while not currently logged in. I don't think I've ever got to a login screen via this route since the forum was tinkered with the other week or so. Only thing working is the site level login.
Proxy Error
The proxy server received an invalid response from an upstream server.
The proxy server could not handle the request
/cas/login
Reason: Error reading from remote server
34 REPLIES 34
Posted on May 19, 2016 at 00:41
Proxy Error
/cas/login
waclawek.jan
Posted on May 19, 2016 at 09:04
Same here. One more obstacle to access this forum, as if there would not be enough of them already.
You forgot to properly tag your post, Clive.
Jan
Posted on May 20, 2016 at 03:35
XML Parsing Error: no element found
Location: https://my.st.com/public/STe2ecommunities/mcu/_layouts/authenticate.aspx
Line Number 1, Column 1:
waclawek.jan
Posted on May 20, 2016 at 06:42
Clicking on the link in the ''Proxy error'' you gave above and logging in resulted in the following message. It sounds like an opportunity to make real harm, but I am not in an a hacking mood this morning.
Confirmation
  • You have successfully logged into the Central Authentication Service.
  • For security reasons, please Log Out and Exit your web browser when you are done accessing services that require authentication!
waclawek.jan
Posted on May 20, 2016 at 10:58
And a new one:
https://my.st.com/content/my_st_com/en.html?ticket=ST-43827-HyQVWfB93azL9zhhNNzy-cas
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, [no address given] and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Amel NASRI
Posted on May 20, 2016 at 11:56
Hi jan & clive,
Please note that issue faced when trying to reply posts is reported internally and is under investigation.
But I would like to understand:
1- When exactly is the error ''
'' displayed?
2- Where do you try to access Jan?
-Mayla-
Kersten HEINS
Posted on May 20, 2016 at 14:07
issue has been fixed. Sorry for the inconvenience.
waclawek.jan
Posted on May 24, 2016 at 15:20
Not yet, or came back.
Not being logged in, having displayed a thread, clicked at Reply, been redirected to login page, it had pre-filled name and password so I just clicked Login, and the following came up:
Proxy Error
/cas/login;jsessionid=2276603017A906CC86EFD1707C4DF95D
Proxy Error
/cas/login
