Blue pill (STM32F1) programs OK via Arduino IDE but not Keil. Chip ID:0x2BA01477
2024-04-29 5:11 AM - last edited on 2024-11-26 1:28 AM by Andrew Neil
I am trying to program STM32 Blue pill board using Keil, and it gives the following error: "Connection refused due to device mismatch; Device connected to debug unit is different from device selected for project target STMicroelectronics STM32F103C8." I am using ST-Link debugger for programming as it does not have on-board ST-debugger. The issue is that it reads chip ID:0x2BA01477, which, I have read on other forums, is the ID read when your board uses clone instead of real STM32F103C8T6. Still, I want to program it using Keil. When I program the same setup using Arduino IDE, it is gets programmed in a perfectly fine way. Is there any other way to resolve this error in Keil using the same board or there is no other option left but to replace the board?
- Labels:
STM32F1 Series
2024-10-06
5:26 AM
- last edited on
2024-10-06
11:37 PM
by
Maxime_MARCHETT
I encountered the same problem today. I searched the community and found that it was because I bought a counterfeit chip.
But it can also be burned using ST-LINK. Just remove the √ sign from the options marked in the picture.
This post has been translated from Chinese to comply with the ST Community guidelines.
2024-11-25 2:24 PM
Thanks!
- « Previous
- Next »
