Big endian and Little endian ?
asterix
Posted on January 09, 2008 at 18:05
5 REPLIES 5
asterix
Posted on May 17, 2011 at 12:20
Hi Folks,
I am tearing my hair out on this one and hoping someone can help :
is STM32 ( Cortex-M3) Little or Big endian and how we can change it at both processor level and in keil or IAR compiler options ? :-?
Thanks , Magigimix
edware
Hi Magigimix,
Here's a quote from the Arm M3 Cortex Technical Reference Manual:
Quote:
The processor can access data words in memory in little-endian format or big-endian format. It always accesses code in little-endian format.
Note
Little-endian is the default memory format for ARM processors.
The processor contains a configuration pin, BIGEND, that enables you to select either the little-endian or BE-8 big-endian format. This configuration pin is sampled on reset.
You cannot change endianness when out of reset.
I hope you still have some hair left!
edware
sjo
No you cannot change the endianess, it is little endian only.
The BIGEND is an internal setting to the cortex die.
Cheers
Spen
asterix
Dear edware,
Thanks so much , I still have some :-) last night.
back to your answer and to conclude : I can change at reset the data endianess only, but how ? I can not see any pin called BIGEND. Thx again.
kind regards, Magigimix
"some hair left" is the reason I thumbed it up.
