harshana_n
Basic Programming techniques
  • June 12, 2011
  • 4 replies
  • 796 views
Posted on June 12, 2011 at 07:17
I'm very new to ST Microcontrollers, is there anywhere i can find a ref manual on basic programming techniques on STMs. I'm good in C but i would like to know how to how to handle I/Os on these.. i.e, how to assign a input port, and how to output something on a port...
 can anyone please help me ?
    ColdWeather
    June 12, 2011
    Posted on June 12, 2011 at 10:43
    1. ARM says about Cortex, CMSIS (core access library) and toolchains - No more Assembler, everything in C!
    2. Download the peripheral
    http://www.st.com/internet/com/SOFTWARE_RESOURCES/SW_COMPONENT/FIRMWARE/stm32f10x_stdperiph_lib.zip
    and take a look at the firmware
    http://www.st.com/stonline/stappl/resourceSelector/app?page=resourceSelector&doctype=FIRMWARE&ClassID=1734
    Surely you must understand the peripheral functions und features to program them properly. Read the
    http://www.st.com/stonline/stappl/resourceSelector/app?page=resourceSelector&doctype=REFERENCE_MANUAL&ClassID=1734
    and
    http://www.st.com/stonline/stappl/resourceSelector/app?page=resourceSelector&doctype=DATASHEET&ClassID=1734
    Tesla DeLorean
    Guru
    June 12, 2011
    Posted on June 12, 2011 at 15:17
    As noted the web resources are quite extensive.
    I found the first edition of Joseph Yiu's book to be quite instructive.
    http://www.amazon.com/Definitive-Guide-ARM-Cortex-M3-Second/dp/185617963X/ref=tmm_pap_title_0?ie=UTF8&qid=1307884045&sr=1-2-catcorr
    http://www.amazon.com/gp/offer-listing/0750685344/ref=dp_olp_all_mbc?ie=UTF8&qid=1307884045&sr=1-2-catcorr&condition=all
    Doing IO on the GPIO pins is fairly similar to most other platforms, perhaps some books on Embedded programming, platforms, interfacing, techniques, etc might be more helpful than stuff specifically about the STM32
    vikas_sinha75
    Visitor II
    July 6, 2011
    Posted on July 06, 2011 at 08:32
    SImply go through the std peripheral library example avaialble at
    . you will get example of most of the peripherals. For more details go through HW CONFIG function under each example carefully all the initiallization etc is availble under this.
    Simply download the firmware from internet and look into the library folder. you will get the desired things over there
    Andrew Neil
    Posted on July 06, 2011 at 08:45
    ''basic programming techniques on STMs''
    Basic programming techniques will be the same whatever microcontroller you're using.
    Keil (an ARM company) give a good list of general embedded progamming books:
    http://www.keil.com/books
     - they are not (all) specific to the Keil tools!
    The things that are specific to the STM32 are to do with its hardware implementation - which is described in the User Manual.
    See the 'Resources' tab at
    http://www.st.com/stm32
    for all the documentation - including Datasheets, Reference Manuals, Application Notes, etc,...
    Also see this recent thread on the forum:
    http://bit.ly/qZ7Vpv
