Automatic NSS-CS management by hardware with SPI
amar1567
Posted on January 16, 2010 at 18:41
amar1567
Posted on May 17, 2011 at 13:38
Hello Sir,
Is Automatic NSS-CS management by hardware by SPI engine working?
In my case it is not working.
Can you please post the example code for ''Automatic NSS-CS management by hardware by SPI engine '' which works on STM3210E-EVAL board.
Please get back.
Amar 🙂
jj
Hello Amar,
STM32 has known ''difficulty'' with ''normal/customary'' NSS signal generation. This was placed on a ''request/fix'' list over a year ago.
You will find several code examples featuring SPI. Suggest you review - you will find that NSS is set/cleared via instruction - to my best knowledge it is not ''auto generated'' - as has been done for years on lesser MCUs. Annoying but can be made to work...
[ This message was edited by: jj.sprague on 16-01-2010 23:11 ]
