2010-01-16 09:41 AM
Automatic NSS-CS management by hardware with SPI
2011-05-17 04:38 AM
Hello Sir,
Is Automatic NSS-CS management by hardware by SPI engine working? In my case it is not working. Can you please post the example code for ''Automatic NSS-CS management by hardware by SPI engine '' which works on STM3210E-EVAL board. Please get back. Thanks Amar 🙂2011-05-17 04:38 AM
Hello Amar,
STM32 has known ''difficulty'' with ''normal/customary'' NSS signal generation. This was placed on a ''request/fix'' list over a year ago. You will find several code examples featuring SPI. Suggest you review - you will find that NSS is set/cleared via instruction - to my best knowledge it is not ''auto generated'' - as has been done for years on lesser MCUs. Annoying but can be made to work... [ This message was edited by: jj.sprague on 16-01-2010 23:11 ]
