ADC do not generate interrupts
Vyacheslav Azarov
Posted on February 29, 2016 at 18:27
I programmed ADC strictly through HAL. Dual injected simultaneously mode, three conversions, triggered by HRTIM. Initialization was generated CubeMX. Was been started through sequence
HAL_ADCEx_InjectedStart_IT(&hadc2);
HAL_ADCEx_InjectedStart_IT(&hadc1);
As result, ADC works but interrupt do not generated and ADC1_2_IRQHandler() do not called. I tried change settings but unsuccessfully. What to do? I'm at an impasse!
Thanks in advance.
#interrupts #interrupts
Vyacheslav Azarov
Posted on March 01, 2016 at 21:10
Excuse me. Problem already solved. Option of HRTIM must be
TimerCfg.PreloadEnable = HRTIM_PRELOAD_DISABLED;
In case other values interrupts and triggers do not generated.
But why?
