About Embedded Resource Editor GUI 2.0
johnzhy9
Posted on February 28, 2012 at 09:00
On my PC(windows 7 32bit)
Create a project named test.erj with 400x240 resolution ,save it and close it.
Then open the test.erj project,but the resolution is 320x240.
Why?
#gui-stm32
johnzhy9
Posted on March 01, 2012 at 03:24
Anybody know?
Posted on March 01, 2012 at 04:24
It's a forum, nobody cares. If you are reporting a bug you should try your local ST FAE or representatives.
''The library has been developed and tested on an LCD panel of QVGA resolution (320x240) which is the default, but the library is independent to the LCD resolution, although it has not been tested with others.''
