About DFU file
wuxiangdong
Posted on December 20, 2009 at 22:40
About DFU file
3 REPLIES 3
wuxiangdong
Posted on May 17, 2011 at 13:34
When I make a DFU file from a Hex/S19/BIN file with DFU File Manager, I must input the infomation below:
1.Target ID
2.VID
3.PID
4.Version
5.Target Name
My question is what the five infomation means?
This is my guess, is this right?
1 > I think that Target ID desided the data will be whrite to where:
00 : Internal Flash
01 : SPI Flash
02 : NOR Flash
03~FF : ?
2 > VID : Vendor ID ?
May I set with any number I will? or just the ''0483'' is valid for ST?
3 > PID : Product ID ?
May I set with any number I will? or just the ''088D'' is valid for STM3210E-EVAL?
4 > Version :
May I set this as I will?
5 > Target Name :
Thanks.
[ This message was edited by: wuxiangdong on 15-12-2009 11:38 ]
armmcu
I geuss all what you need is already available through this link:
http://www.st.com/stonline/products/literature/um/13379.pdf
Cheers.
wuxiangdong
Cheers.
Oh, Thanks for answer.
I had read this document before I saw your answer.
But this document just tell me what those are, and I do more care about wether I can write the VID/PID/Version as I will.
For example, if I write 0x0000 for VID, do I meet some trouble?
however,thank a lot.
[ This message was edited by: wuxiangdong on 21-12-2009 03:12 ]
