24C16RP EEPROM INTERFACING WITH STM32G070CBT6
RChou.1
Hello all,
I am trying to interface 24C16RP EEPROM with my MCU soldered on breakout board and  it seems like the EEPROM is behaving very weird when i am trying to write and read. first of all it starts to write from position 1 not from zero of an array that i have created to store the data and i tried a lot to figure out the cause but i couldn't and the weird part is that after writing to a specific page if am trying to read any other page of the entire page address it returns the same date i have written to it. As i know this EEPROM has 16 byte of page size and 128 pages correct me if i am wrong. With that said i am attaching the cube mx code and the ioc file and some screen short for your better understanding. Please help me if you find something error in my code.
uint8_t data_Read[16];
uint8_t data_Write[16]="1234567898765432";
int main(void)
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_I2C1_Init();
  MX_USART1_UART_Init();
  HAL_I2C_Mem_Write(&hi2c1, 0XA0, 1, 2, data_Write, 16, 1000);
  HAL_Delay(5);
  HAL_I2C_Mem_Read(&hi2c1, 0XA0, 9, 2, data_Read, 16, 1000);
  while (1)
  HAL_UART_Transmit(&huart1, data_Read, 16, 1000);
  HAL_Delay(1000);
11 REPLIES 11
Pavel A.
Evangelist III
As you've mentioned above the page size of this EEPROM is 16 bytes.
What do you think will do the above code line? (write 16 bytes, from index 1) ? Is this intentional (you want to test how the wrap-around works?)
MHoll.2
I don't understand what you try to do, but reading the datsheet of the 24C16RP, You will see that this device has only a 1 Byte Address length, so the 4. parameter has to be 1. With 2 the device will write the low part of Your address to the EEPROM!
  * @brief  Write an amount of data in blocking mode to a specific memory address
  * @PAram  hi2c Pointer to a I2C_HandleTypeDef structure that contains
  *                the configuration information for the specified I2C.
  * @PAram  DevAddress Target device address: The device 7 bits address value
  *         in datasheet must be shifted to the left before calling the interface
  * @PAram  MemAddress Internal memory address
  * @PAram  MemAddSize Size of internal memory address
  * @PAram  pData Pointer to data buffer
  * @PAram  Size Amount of data to be sent
  * @PAram  Timeout Timeout duration
  * @retval HAL status
HAL_StatusTypeDef HAL_I2C_Mem_Write(I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint16_t MemAddress,
                                    uint16_t MemAddSize, uint8_t *pData, uint16_t Size, uint32_t Timeout)
Martin
i want to know why it starts writing from index 1 and the data which should be written on 15th place is getting written on 0th place and if i am trying to read the data of any other page it returns me the same data.
Did You read my response?
This Eeprom has only 1 Byte of Address, to access the full 2K array you have to put the 3 high Bit's in DevAddress ( 0xA0, will give You the first 256 Byte, 0xA2 the next 256 Byte etc.)
Please read the datasheet.
Martin
I have gone through your response and  as you said i made that changes to the I2C MEM Write function but in your second response what you said is completely out of my mind so, can you please give me a short example code that will give me a clear vision.
uint8_t Buffer[16];
HAL_I2C_Mem_Write(&hi2c1, 0xA0, 0, 1, Buffer, 16, 100);  // write 16 Byte to first 16 Byte of EEprom
HAL_I2C_Mem_Write(&hi2c1, 0xA2, 0, 1, Buffer, 16, 100);  // write 16 Byte starting from Byte 256 of EEprom
HAL_I2C_Mem_Read(&hi2c1, 0xA0, 0, 1, Buffer, 16, 100);  // read first 16 byte from eeprom
HAL_I2C_Mem_Read(&hi2c1, 0xA2, 0, 1, Buffer, 16, 100);  // read 16 Byte starting with Byte 256 from eeprom
It means i can only access 64 pages(1024/16=64) with 0xA0 address and for the next 64 pages i have to use 0xA2 address. Please correct me if i am wrong.
No The MemAddress is only 1 Byte, so You can access only 256 Byte with the same DevAddress  (256/16 = 16 pages).
uint8_t data_Write[16]="hello James...!!";
HAL_I2C_Mem_Write(&hi2c1, 0xA0, 0, 1, data_Write, 16, 100);
HAL_I2C_Mem_Read(&hi2c1, 0xA0, 6, 1, data_Read, 16, 100);
It returns me the same data i saved in 0th page. When i can access 256 byte it means 16th page can be read with the same address, then why the 6th page is returning me the same data saved on 0th page.
