2025-02-27 4:01 PM - last edited on 2025-02-28 1:19 AM by mƎALLEm
Does STM currently have a guideline or recommendation(s) for handling the 2038 problem?
2025-02-27 7:44 PM
What is it?
2025-02-27 9:56 PM
2025-02-28 12:04 AM
You mean the year 2038 problem - as @repaint suggested ?
Where do you see that being a specific issue for the STM32 ?
2025-02-28 3:38 AM
You ask about a problem with systems which measure Unix time .
But here is not a Unix system, but just a controller with RTC , that has only years 10 + 1 in BCD : 2025 is only "25" in RTC :
So its up to you, how you handle the full date in your software :
if using a uint_16t to store the "full" year, you will get a problem in the year 65536 - if your device still running and in use. How long you expect it working and be in use ?
