Using the Motor Control Workbench Monitor on custom board
ABouv.1
I am using a custom board and I would like to use the Motor Control Benchs Custom Monitor.
As far as I understand I have to activate serical communication and simply generate and flash my custom board.
My problem is that I can not connect to my custom board. I thought that this might be the case because I only use an ST-Link to connect to my board (so just 4 cables).
Can someone help me out? What am I doing wrong? Do I have to connect something different to the ST-Link adapter?
Laurent Ca...
Lead II
Dear ABouv.1
Do you have still this problem to solve?
Best regards
Laurent Ca...
Dear @ABouv.1​
I guess you don't have to solve this problem anymore, therefore I consider this post closed.
If not, feel free to reopen it by posting a new answer.
Best regards
Laurent Ca...
