Single timer for encoder on Channel 1 & 2 and PWM generation on Channel 3?
‎2024-10-07 5:01 AM - last edited on ‎2024-10-07 5:57 AM by Andrew Neil
Hi. I'm using the STM32F407VE6 Microcontroller board. Is it possible to use a single timer to generate PWM from channel 3 and read the encoder values from channel1 & 2 of the same timer?
When I tried using 2 different timers, one for PWM and the other for the encoder it worked fine.
If it's impossible to use the same timer for both operations, why are channels 3 and 4 available for PWM generation?
‎2024-10-07 5:12 AM - edited ‎2024-10-07 5:13 AM
Timers have a single counter register. You cannot use a timer for an encoder and for PWM at the same time.
‎2024-10-07 6:29 AM
Even with the counter clocked from the encoder, you may find uses for the compare features, including the functionality which is called PWM. You may for example want generate a pulse when a rotary encoder rotates through some portion of its path.
