P-NUCLEO-IHM003 and AN5464 not working because of G4 rev Y errata issue with ADC ?
Tore Kallevik
There is only a very small movement of the motor shaft one time back and forth.
I've verified right connection and correct signals from my ABZ encoder.
Could this problem be linked to G4 rev Y errata issues with ADC ?
Laurent Ca...
Lead II
Dear @Tore Kallevik​
Sorry for the late answer.
Do you have still this problem to solve?
And just in case, if not, do not hesitate to share the final solution you found. Thanks by advance.
Best regards
Laurent Ca...
