need a 5kW motor driver board
SivaVishnu09
Hi all,
       I'm Siva, and i need a BLDC motor driver to run a 5kW motor. please suggest me in buying out the right driver board. the voltage needed for the motor is 48 volt and the current needed will be 180A.
Zied b.
I suggest the St Mc Suite tool, which lists you the Motor Control compatible boards with the details, Here is the link : https://www.st.com/st-mc-suite/home/
- Click on - Start -> Engine Control Solution
- select the motor type (BLDC)
- select the algorithm
- then choose your board in Power Board
The STEVAL-CTM009V1 board can meet your expectations.
If you agree with my answer, please accept it by clicking on "Accept as solution".
SivaVishnu09
also a motor driver which is capable of doing 6 step commutation and FOC advanced algorithms.
Zied b.
