JRE for MCSDK 5.4.8 MotorWorkbench?
SKled.1
Senior II
I installed MCSDK 5.4.8 and CubeMX 5.2, which runs, so, if it uses Java, a suitable version must be installed.
But when I try to Generate from a MotorWorkbench project, it gives me this error:
Generation process failed. The embedded JRE was not found. Please check the correctness of installation.
How do I fix this problem? [I assume I can't just install any JRE willy nilly]
0 REPLIES 0
