how to set p-nucleo-ihm001 to be Single shunt to active BR2804-1700kV.
hchon.1
follow the quick-start, i can set three shunt to active BR2804-1700kV.
but when i use single shunt, it always occured overload current.
when i set single shunt, i set the settting as the appendix
Gael A
Hello hchin.1,
First of all, we would like to apologize for the delay in replying to your post.
If your point is still relevant, I would like to ask you if you have moved the jumper related to 1-Shunt configurations on the IHM07. They normally are set on 3-Shunt configuration, this may be the issue you are facing.
If you agree with my answer, please consider accepting it by clicking on 'Accept as solution'.
Hope this will help,
Gaël A.
