FOC duration and Software error in MCSDK
vishu
Sir i am now working on STEVAL-SPIN3201 evaluation board having 6-step commutation method. I'm unable to rotate motor. I got errors like FOC duration and Software error. I also increased the execution rate one by one . still the motor is not rotating. I attached snapshot for reference. Kindly let me know
4 REPLIES 4
SRedd.5
Senior III
I am bit confused are you using the 6 step commutation or the FOC as both are different?
Sir i am working on 6-step commutation method
Is STEVAL-SPIN3201 supports six-step commutation?
In Example projects i can only see FOC not 6 step from MCSDK 6.2.0, you have to write the code on your own by taking reference from other projects i think.
