External memory on stspin32g4 possible
Schmesterle
Hello
Is it possible to connect an external memory IC to the stspin via qspi or spi interface and map the addresses into the addressable space of the cpu?
STM32G431VB is the chip on the stspin32g4 board!
https://www.st.com/en/motor-drivers/stspin32g4.html
4 REPLIES 4
Andrew Neil
Have you looked at the datasheet for the STM32G431VB ?
Schmesterle
Didn't look into other products, because we need the stspin with integrated drive stage.
Schmesterle
Ah, now I understand you. Thank you very much for this hint. I will take a look into the MCU!
