TThan
Documentation of ASPEP Protocol?
  • August 10, 2021
  • 12 replies
  • 11649 views
As stated in UM1052, chapter 14 there is often a requirement to control a BLDC motor control board over a serial connection. The above manual describes the protocol used by older MCSDKs. But the latest MCSDK 5.Y.x seems to use a slightly different procol called ASPEP.
Unfortunately I could not find a documentation for that protocol on the ST web site.
My question is: Is there any documentation of that new protocol or is it required to reverse engineer the STM source code to use it with an different application than the Motor Pilot?
Thank you for any hints!
Best Regards
Thomas
Best answer by Zied b.
Hello everyone, the MCP & ASPEP documentation is provided in the package. The fastest way to find it is through the Motor Control Workbench:
- Open Mc Workbench
- Click top right on "About" button
- Click on "Documentation" -> "Documentation
- Click on "User Manual"
- And finally click on Motor Control Protocol Suite
As it is HTML documentation you can also enter this link in your browser: (replace _your_install_folder_)
file:///C:/_your_install_folder_/MC_SDK_6.1.1/Documentation/html/motor-control-protocol-suite.html
Laurent Ca...
Senior III
September 5, 2021
Dear @TThan​
I just got back from vacation.
Have you found an answer to your question in the meantime?
Best regards
Tesla DeLorean
Guru
September 5, 2021
Post a link to the protocol specification, that will have reach beyond the OP, that way subsequent searchers will be able to find it more readily.​
CZhen.1
Hi Tesla, you mentioned that you posted a link to the protocol specification. Where is the link? Could you please post it again so that I can have it as well? Thank you so much.
TThan
TThanAuthor
Sorry, unfortunately I have not found an official documentation until today.
I just proceeded with some reverse engineering and that is working up to the amount of functionality I need for the current project. But that is my internal crude documentation only. Please understand that I do not want to share,
Quentin Ch
Hello ST team (@Laurent Ca...​ )
Now that MCSDK 6.x has been released, are there any plans for a documentation of the ASPEP/MCP protocol ?
VOgne.1
Visitor II
October 15, 2022
I created a simple python file which makes some basic communication with MCSDK. It is based on source code exploring with a debugger. Most relevant code is placed in aspep.c, mcp.c, and register_interface.c files.
Visitor II
June 26, 2024
this post deserves more credit :p Thanks for the code
XPua.1
Hello. is there any follow up on the documentation of the ASPEP Protocol?
SL.2
Visitor II
June 1, 2023
Same question as above. Is there any documentation on the ASPEP Protocol?
EMart.14
Visitor II
June 4, 2023
I also would like the ASPEP Protocol documentation!
Zied b.Best answer
- Open Mc Workbench
"If you agree with my answer, please accept it by clicking on ""Accept as solution""."
Hello everyone, for people who ask for documentation on the communication protocol used in the mcsdk:
- Open Mc Workbench
