Complementary output is active high when disabled
2021-11-30 2:06 AM
I want to control output of complementary PWM.I am doing it as follows:
while (1)
/* USER CODE END WHILE */
TIM1->CCR2 = 30000;
HAL_Delay(15000);
TIM1->CCER &= (uint16_t) ~TIM_CCER_CC2E;
HAL_Delay(15000);
TIM1->CCER|=TIM_CCER_CC2E;
/* USER CODE BEGIN 3 */
But when i disable my CH2N(marked in bold),it is active high by default.and i want it to be active low when i disable output.
below is my configuration:
- Labels:
STM32 Motor Control
2021-11-30 1:47 PM
It's not clear if you're talking about OC2N or OC2 output, but in either case, the output state is dependent on several parameters as described in the reference manual:
