error when analyzing the .onnx model in stm32cubeMX by stm32cube.AI
2022-07-08 7:10 AM
Hi, Thanks for your attention. I am analyzing the .onnx format model but an error occurs. I try to reinstall the stm32cubeMX but it doesn't help.
The part of architecture is:
Here is the log information. Can you help me with this problem? @Romain LE DONGE @jean-michel.d @fauvarque.daniel Thanks very much!
2022-07-08 15:39:51,314 [INFO] BoardInfo:879 - No configuration file found for board P-NUCLEO-WB55
2022-07-08 15:39:51,316 [INFO] DbBoards:156 - Kit is not supported: P-NUCLEO-WB55
2022-07-08 15:39:51,319 [INFO] BoardInfo:879 - No configuration file found for board STEVAL-BFA001V1B
2022-07-08 15:39:51,320 [INFO] DbBoards:156 - Kit is not supported: STEVAL-BFA001V1B
2022-07-08 15:39:51,321 [INFO] BoardInfo:879 - No configuration file found for board STEVAL-BFA001V2B
2022-07-08 15:39:51,321 [INFO] DbBoards:156 - Kit is not supported: STEVAL-BFA001V2B
2022-07-08 15:39:51,404 [INFO] DbBoards:160 - Found 176 boards, 173 are supported
2022-07-08 15:39:51,408 [INFO] ApiDb:418 - Load user favorites file /Users/name/.stm32cubemx/favorites.boards.txt: 0 item(s)
2022-07-08 15:39:51,408 [INFO] ApiDb:422 - User favorites Boards=[]
2022-07-08 15:39:51,409 [INFO] DbBoards:189 - Set 0 / 0 favorites Boards
2022-07-08 15:39:56,930 [INFO] ExtendedFilter:65 - Artificial Intelligence: enable filter
2022-07-08 15:39:56,938 [INFO] McuExtendedFiltersManager:86 - Reset MCU extended filter: Artificial Intelligence
2022-07-08 15:40:11,418 [INFO] AInterface:235 - ModelName:network; files:[/Users/name/STM32Cube/test.onnx]; type:ONNX; compression:None
2022-07-08 15:40:11,434 [INFO] AInterface:515 - workspaceTempDir: /var/folders/y8/7c4vvzbj2l1dw7trnz05b52m0000gn/T/mxAI_workspace5038345178307913369027895421033696
2022-07-08 15:40:11,438 [INFO] AInterface:1065 - Setting Env: /Users/name/STM32Cube/Repository//Packs/STMicroelectronics/X-CUBE-AI/7.2.0/Utilities/mac
2022-07-08 15:40:11,440 [INFO] AInterface:1122 - Custom PATH variable: /Users/name/STM32Cube/Repository//Packs/STMicroelectronics/X-CUBE-AI/7.2.0/Utilities/mac:/bin:/usr/bin:/usr/sbin:/sbin:/Users/name/STM32Cube/Repository//Packs/STMicroelectronics/X-CUBE-AI/7.2.0/Utilities/mac/node/bin
2022-07-08 15:40:11,500 [INFO] CmdLine:100 - Command: /Users/name/STM32Cube/Repository//Packs/STMicroelectronics/X-CUBE-AI/7.2.0/Utilities/mac/stm32ai analyze --name network -m /Users/name/STM32Cube/test.onnx --type onnx --compression none --verbosity 1 --workspace /var/folders/y8/7c4vvzbj2l1dw7trnz05b52m0000gn/T/mxAI_workspace5038345178307913369027895421033696 --output /Users/name/.stm32cubemx/network_output --allocate-outputs
2022-07-08 15:40:12,022 [INFO] CmdLine:132 - stm32ai exit with status: 132
2022-07-08 15:40:12,025 [ERROR] CmdLine:135 - stm32ai return with an error
X-CUBE-AI
2022-07-08 7:26 AM
@VTOMA.1
2022-07-08 7:52 AM
I have checked that all the layers in my .onnx model are supported.
Please refer to ..../STM32Cube/Repository/Packs/STMicroelectronics/X-CUBE-AI/7.2.0/Documentation/supported_ops_onnx.html
2022-07-08 8:37 AM
Do you have the same error when running the stm32ai command by hand in a terminal window ?
just type
/Users/name/STM32Cube/Repository//Packs/STMicroelectronics/X-CUBE-AI/7.2.0/Utilities/mac/stm32ai analyze /Users/name/STM32Cube/test.onnx
Daniel
2022-07-08 10:12 AM
Dear fauvarque.daniel @fauvarque.daniel ,
Thanks for your quick reply. I try the follow exec command but get the error: illegal hardware instruction. I am using an M1 pro chip in Macbook pro 14inch.
There is the same question unsolved here.
Looking forward to your reply.
2022-07-11 12:23 AM
The current generation for Mac is done for x86 based mac assuming that Apple has implemented a backward compatibility with the x86 applications.
It doesn't seem to be the case, we'll have to investigate how to solve the issue (specific build for the M1 ?)
Daniel
2022-07-11 12:53 AM
Dear Daniel,
Thanks for your reply and help.
Yes, I think at present M1 can't work. M1 Mac needs a specific build.
There is another question related to this problem highly. Please refer to https://community.st.com/s/question/0D53W00001dwl1GSAQ/stm32ai-illegal-hardware-instruction-on-mac-m1
Looking forward to your solution. @fauvarque.daniel
Best wishes,
Baichuan
2022-07-11 1:24 AM
Hi @BHuan.3
I just replied the thread you mentioned,
Can you try enabling manually Apple's Rosetta 2 compatibility layer using the solution from this thread: https://github.com/nvm-sh/nvm/issues/2350#issuecomment-734132550
Then try running again the stm32ai command line call
Hope it can help,
Romain
2022-07-11 9:58 AM
@Romain LE DONGE
Dear Romain,
Thanks for your quick and kind reply. I try it but fail.
That is sad news. Maybe we need a new build one for M1 specifically or use windows instead.
Best wishes,
Baichuan
2023-07-27 3:28 AM
Hi @fauvarque.daniel, I have same issue on my macbook m2pro, are you planning to fix that issue?
