USBx Msc not working on STM32H563-Nucleo board
‎2024-10-21 9:30 AM
I have got the filex + levelx working with qspi nor flash chip ( 16 MB size )along with threadx.
However I am not able to get the USBX MSC to work to see the files by attaching the STM32H563 Nucleo board to a PC.
But the USBx stack doesn't seem to work. I have checked and used all the code from a ready STM32H573 discovery project give by ST Micro.
The USBPD stack uses the void USBPD_DPM_Notification(uint8_t PortNum, USBPD_NotifyEventValue_TypeDef EventVal) function to call start the USB interface.
But the USBPD_DPM_Notification() doesn't get called.
I am unable to get the USBx CDC ACM working along side Filex as well.
STM32H5 Series
UCPD
USB
‎2024-10-24 10:24 AM
Hi @FBL ,
I got the USBx msc working with filex + levelx.
Increased the UX_THREAD_STACK_SIZE for the task "ux_slave_storage_thread" from 1024 to 1536 bytes.
The stack of this task overflowed when the USB host ( in my case Windows machine ) tried to read the media ( Nor flash device ).
‎2024-10-22 3:08 AM
Hello @sourcerrer
First, are you enabling the TrustZone?
‎2024-10-22 8:25 AM
Hi @FBL ,
I have not enabled TrustZone.
The device class does not get enumerated. i tried for both the ACM and storage class.
The ACM+HID ready example is working on my Nucleo-H563ZI board.
The USBPD is working. I had not added the stm32h5xx_nucleo_usbpd_pwr.c file in the BSP folder.
‎2024-10-23 9:55 AM
Hi @sourcerrer
If I understand correctly, ACM is not working alone. But works on ACM+HID example.
I propose you to start with ACM+HID and comment out ux_hid_thread!
Otherwise, can you point me directly to the issue linked to mass storage?
Hi @FBL ,
