USB Host MSC - NULL byte in 512 byte block read.
Options
2019-05-15 2:22 AM
Hello everyone,
I'm using the STM32 Host library with FreeRTOS FAT, but when i read from a specific usb key, I always get a NULL ( 0x00 ) inserted at the beginning of the second 512 bytes block I read. If I put a breakpoint between every packet they are all ok. This happens only with one 512 MB usb Key. With all the others one everything works fine. I need i rock solid firmware so i can't ignore this problem and change the usb key.
Any idea of what i need to look for?
Thank you,
Luca
Labels:
- Labels:
STM32Cube MCU Packages
USB
0 REPLIES 0
