USB CDC VCP help to receive Data from PC
maxyork145
Posted on July 09, 2013 at 20:09
Hello everybody (This about USB VCP)
i started an application to send and receive data from PC to STM32F4 discovery
i used the titorial provided by STmicro, but the problem i'm not able to sent to the STM32F4Discovery (PC to STM32), only from Discovery to PC
i use this function to send to PC, she work fine, but i can't find how receive data from PC, anything can help me.
The function blow provide to send Data to PC
static uint16_t VCP_DataTx (uint8_t* Buf, uint32_t Len)
  if (linecoding.datatype == 7)
    APP_Rx_Buffer[APP_Rx_ptr_in] = USART_ReceiveData(EVAL_COM1) & 0x7F;
  else if (linecoding.datatype == 8)
    APP_Rx_Buffer[APP_Rx_ptr_in] = USART_ReceiveData(EVAL_COM1);
  APP_Rx_ptr_in++;
  /* To avoid buffer overflow */
  if(APP_Rx_ptr_in == APP_RX_DATA_SIZE)
    APP_Rx_ptr_in = 0;
  return USBD_OK;
#usb-vcp-need-receive-function
2 REPLIES 2
Posted on July 09, 2013 at 20:23
As I recall I just had the VCP_DataRx() routine send data out the USART, but it could just as easily put it in a buffer.
gvigelet2
Posted on July 17, 2013 at 20:32
Clive is correct it is the following function that receives the data from the PC (via usb) and passes the data to the UART.
  * @brief  VCP_DataRx
  *         Data received over USB OUT endpoint are sent over CDC interface
  *         through this function.
  *         @note
  *         This function will block any OUT packet reception on USB endpoint
  *         untill exiting this function. If you exit this function before transfer
  *         is complete on CDC interface (ie. using DMA controller) it will result
  *         in receiving more data while previous ones are still not sent.
  * @param  Buf: Buffer of data to be received
  * @param  Len: Number of data received (in bytes)
  * @retval Result of the opeartion: USBD_OK if all operations are OK else VCP_FAIL
static uint16_t VCP_DataRx (uint8_t* Buf, uint32_t Len)
  uint32_t i;
  for (i = 0; i < Len; i++)
    USART_SendData(EVAL_COM1, *(Buf + i) );
    while(USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TXE) == RESET);
  return USBD_OK;
If you are looking for the trail the data travels, the data comes from the PC over usb which is handled by the USBD_CDC library through function usbd_cdc_DataOut
  * @brief  usbd_cdc_DataOut
  *         Data received on non-control Out endpoint
  * @param  pdev: device instance
  * @param  epnum: endpoint number
  * @retval status
static uint8_t  usbd_cdc_DataOut (void *pdev, uint8_t epnum)
  uint16_t USB_Rx_Cnt;
  /* Get the received data buffer and update the counter */
  USB_Rx_Cnt = ((USB_OTG_CORE_HANDLE*)pdev)->dev.out_ep[epnum].xfer_count;
  /* USB data will be immediately processed, this allow next USB traffic being
     NAKed till the end of the application Xfer */
  APP_FOPS.pIf_DataRx(USB_Rx_Buffer, USB_Rx_Cnt);
  /* Prepare Out endpoint to receive next packet */
  DCD_EP_PrepareRx(pdev,
                   CDC_OUT_EP,
                   (uint8_t*)(USB_Rx_Buffer),
                   CDC_DATA_OUT_PACKET_SIZE);
  return USBD_OK;
the APP_FOPS.pIf_DataRx(USB_Rx_Buffer, USB_Rx_Cnt); command passes it to your defined handler which is configured with a define in your usbd_conf.h file
#define APP_FOPS                        VCP_fops
Hopefully this helps enough.
