Help with Ethernet configuration
Palacios.Bruno
Posted on July 18, 2013 at 20:18
Hello guys, I need some help. Im trying to interface a stm32f407 with a lan8720 via RMII interface using an external clock source from the PHY.
I was able to measure the 50MHz sine wave generated by the PHY, but I can't see any comunication between chips. I mean, MDC is always low and MDIO is always high (because there's a pull up resistor). Below is the code. I'm pretty sure that there's a problem related with the external reference clock. It seems like the MAC it's not running. I think there's something wrong configured. The code is based on [DEAD LINK /public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/MDC%20MDIO%20stay%20low%20forever%20after%20configuring%20RMII%20%20Ethernet%20on%20STM32F4&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B&currentviews=520]this post. Best regards!
void ETH_GPIO_Config(void)
uint16_t i = 0;
// Data structure to represent GPIO configuration information
// Enable the peripheral clocks
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_GPIOB |
RCC_AHB1Periph_GPIOC | RCC_AHB1Periph_GPIOD,
ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE); // Early
// Configure PD8 (RMII_nRST)
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
GPIO_Init(GPIOD, &GPIO_InitStructure);
// Hold the Ethernet PHY in reset
GPIOD->BSRRH = 0x100;
// Set RMII mode while in reset
SYSCFG_ETH_MediaInterfaceConfig(SYSCFG_ETH_MediaInterface_RMII);
//GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
// Configure PA1, PA2 and PA7 (RMII_REFCLK, RMII_MDIO, RMII_CRS_DV
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_7;
GPIO_PinAFConfig(GPIOA, GPIO_PinSource1, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_ETH);
// Configure PB11 (RMII_TXEN), PB12 (RMII_TXD0), PB13 (RMII_TXD1)
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13;
GPIO_PinAFConfig(GPIOB, GPIO_PinSource11, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource12, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource13, GPIO_AF_ETH);
// Configure PC1, PC4 and PC5 (RMII_MDC, RMII_RXD0, RMII_RXD1)
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_4 | GPIO_Pin_5;
GPIO_PinAFConfig(GPIOC, GPIO_PinSource1, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource4, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource5, GPIO_AF_ETH);
for(i = 0; i <
20000
; i++); // PHY Out of reset
GPIOD->BSRRL = 0x100;
ENABLE);
for(i = 0; i <
20000
#stm32 #discovery #ethernet-phy
6 REPLIES 6
Posted on July 18, 2013 at 21:06
The link doesn't work for me.
The code doesn't look wrong.
You are aware the PHY is at a different address than the DP83848, right?
Palacios.Bruno
Posted on July 18, 2013 at 21:26
Hi Clive1,
Thank you for your answer.
I read it somewhere, but should I worry about that now? Or I'm missing something? Because, for me, the main problem is I can't establish the comunication between mac and phy =/. But as Im a newbie with ethernet and st maybe there's something I'm missing.
Did you use the 50MHz source clock from lan8720? Or from the MCO pin?
Best regards!
Posted on July 18, 2013 at 22:45
The design I looked at generated 25 MHz out the MCO pin from the HSE. The SMSC8720A was strapped to use a 25 MHz source. You could perhaps use MCO to generate 50 MHz if the PLL ran the CPU at a multiple of 50 MHz (ie 150 MHz).
Palacios.Bruno
Posted on July 18, 2013 at 23:09
Yes, I can use the MCO, but I will have to redesign my board and I want to avoid it.
I've realize that the 25MHz signal generated by the crystal it's mounted on a 3KHz ''almost sine'' wave O.O
And the 50MHz output sine is mounted on a 6KHz sine. That is wear and I don't why it happends.
I am totaly confused.
Posted on July 19, 2013 at 02:02
What do you have right now as a clock source (part#), and what pins is that attached too?
Palacios.Bruno
Posted on July 19, 2013 at 02:18
Well, I was, finally, able to get it work. The code is the same used in
http://www.backwoodsengineer.com/2013/02/geeky-post-stm32f4-bb-ethernet-projects.html
. The low frec sine mounted on the crystal was present in the stm32f4 8MHz crystal too. And I measure in another board and same situation, so it could be my osc or I don't know, lol. Thank you for all clive1, I really appreciate your help. Best regards,
volatile uint32_t i;
/* Enable GPIOs clocks */
| RCC_AHB1Periph_GPIOC | RCC_AHB1Periph_GPIOD, ENABLE);
/* Enable SYSCFG clock */
/* MII/RMII Media interface selection --------------------------------------*/
/* Ethernet pins configuration ************************************************/
ETH_MDIO --------------> PA2
ETH_MDC ---------------> PC1
ETH_RMII_REF_CLK-------> PA1
ETH_RMII_CRS_DV -------> PA7
ETH_MII_RX_ER -------> PB10
ETH_RMII_RXD0 -------> PC4
ETH_RMII_RXD1 -------> PC5
ETH_RMII_TX_EN -------> PB11
ETH_RMII_TXD0 -------> PB12
ETH_RMII_TXD1 -------> PB13
ETH_RST_PIN -------> PE2
/* Configure PA1,PA2 and PA7 */
/* Configure PB10,PB11,PB12 and PB13 */
/* Configure PC1, PC4 and PC5 */
/* Configure the PHY RST pin */
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
GPIO_ResetBits(GPIOD, GPIO_Pin_8);
for (i = 0; i < 20000; i++);
GPIO_SetBits(GPIOD, GPIO_Pin_8);
