UM0427 - firmware library - is missing!
st3
Posted on January 08, 2010 at 12:41
#stdperiph #um0427 #firmware-library
9 REPLIES 9
st3
Posted on May 17, 2011 at 13:37
The UM0427 PDF file is missing from the downloads page! :(
http://www.st.com/mcu/familiesdocs-110.html
The zip file contains only a .chm help file - there is no PDF document! :(
16-32micros
Dear ST7
Read this AN :
http://www.st.com/stonline/products/literature/an/15531.pdf
Page 10 :
1.2 STM32F10xxx standard peripheral library with doxygen format
The STM32F10xxx standard peripheral library comes in a new source file format. Now, all StdPeriph_Lib files use the Doxygen format to easy documentation generation and for more interactive and effective documentation usage.
The existing STM32F10xxx firmware library user manual UM0427 will be removed from the STMicroelectronics MCU website (www.st.com/mcu) and replaced by a CHM file presenting all STM32F10xxx standard peripheral library components.
Cheers,
STOne-32.
st3
I think that's a really bad idea! :|
Andrew Neil
Evangelist III
The trouble with stuff that's just created from code comments is that it's too ''fine-grained'' - it can't show the wood from the trees.
In addition to this level of detail, we also need an ''overview'' document that shows the ''philosophy'' and overall organisation of the library.
We need something that describes how to actually use the library  - not just fine-detail descriptions of what individual functions do.
See also: [DEAD LINK /public/STe2ecommunities/mcu/Lists/ARM%20CortexM3%20STM32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/ARM CortexM3 STM32/Where can I find a STM32F10x library documentation&currentviews=16]https://my.st.com/public/STe2ecommunities/mcu/Lists/ARM%20CortexM3%20STM32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/ARM%20CortexM3%20STM32/Where%20can%20I%20find%20a%20STM32F10x%20library%20documentation&currentviews=16
trevor1
I'm a big doxygen fan so I can see why ST did this - to make life easier for ST (but unfortunately not for you). Two solutions:
1) You convert chm to PDF
2) ST configure doxygen to also produce pdf (I know it can produce text and HTML so making a PDF should be possible).
jontitus
You can find an archived copy of UM0427 User Manual, ''ARM-based 32-bit MCU STM32F101xx and STM32F103xx firmware library'' (527 pages) at:
http://www.datasheetarchive.com/UM0427-datasheet.htm
.  Scroll down the page to locate the download section. --Jon
Andrew Neil
Evangelist III
You can download an archived copy of the entire old FW Library direct from ST - and that, obviously, includes the UM0427 PDF Manual
But that old UM0427 PDF Manual obviously refers to the old FW Library - it's not much help for use with the new library!
thomaspfeffer9
Posted on July 12, 2011 at 18:48
And where do I find this famous CHM-Document?
Andrew Neil
Evangelist III
Posted on July 12, 2011 at 23:52
It's included as part of the firmware library download
