STM32L4S5 COM PORT not visible
Ashar.1
Hi, I have STM32L4S5 (STM32 Discovery Kit - IoT mode), Part number: B-L4S51-IOT01A.
https://www.st.com/en/evaluation-tools/b-l4s5i-iot01a.html
This is the first time I am using this device.
When I plug this device into Windows 10 machine, I am not able to connect to the device. I do not see any COM port in Device manager and also Tera Term serial port option is greyed out.
I did install STSW-LINK009. I have tried this is 3 windows device and getting same issue.
I noticed that Red line is blinking on the board, while green light is stable.
Device manager
Tera term
Installed ST programs
 ports
Thanks,
Ajay
Try the other USB connector to the ST-LINK​
4 REPLIES 4
Ashar.1
Actually I have tried this on 3 windows machine connecting with all USB ports available.
Try a different cable. Charging cables won't work for data connectivity.
Changing cable helped. Thank you for your suggestion.
