STM32L Flash HalfPageProgram problem
martin2399
Posted on April 18, 2015 at 23:00
I am not able to program the flash of a STM32L151RC using ''half page'' programming.
Normal programming (word by word) works fine.
I have tried it using the 2 latest GCC compilers (4.8.4), and I have tried with the 2 latest HAL drivers (1.1.0 and 1.1.1).
The code below stops working when the 32 words are being written to flash. The debugger stops working. When running the code without a debugges, it also doesn't work.
Am I the only one with this observation?
Best regards
Martin
HAL_FLASH_Unlock();
__HAL_FLASH_CLEAR_FLAG(FLASH_FLAG_WRPERR);
__HAL_FLASH_CLEAR_FLAG(FLASH_FLAG_PGAERR);
__HAL_FLASH_CLEAR_FLAG(FLASH_FLAG_SIZERR);
__HAL_FLASH_CLEAR_FLAG(FLASH_FLAG_OPTVERR);
__HAL_FLASH_CLEAR_FLAG(FLASH_FLAG_OPTVERRUSR);
__HAL_FLASH_CLEAR_FLAG(FLASH_FLAG_RDERR);
uint32 data[32] = { 0 };
if (HAL_FLASHEx_HalfPageProgram(0x08004000, data) == HAL_OK)
// Success
else
// Error
#stm32l-hal-driver-flash-write #iap-flash-half-page-program
7 REPLIES 7
kobus
Posted on January 12, 2016 at 23:22
I ran into a similar issue while developing a IAP bootloader for a stm32L1 device. I was modifying an existing bootloader for an F1 device, and found that on the L1 device the flash writes took far too long in word program mode. I tried the HAL_FLASHEx_HalfPageProgram function, but it only seemed to crash.
As I found, this is because the hal library  __ramfunc macro (for gcc) tries to place the function in a memory section called '.RamFunc' which does not exist in the standard linker script for the stm32. I modified my linker script to include a .Ramfunc section in the .data block, and it now works fine.
Hope this helps someone
anthony239955_st
Posted on June 27, 2016 at 09:12
I am also having some issues with using HAL_FLASHEx_HalfPageProgram()
I have my bootloader and my application in Memory bank1, and my downloaded image in memory bank 2.
In bootloader I am trying to write in memory bank 1 (application) , the data located in memory bank 2 (downloader image).
but this process is not working. I am constantly having a PGAERR error.
This is the code: numBytes = 237568, address=0x08006000
if (((numBytes % 128) == 0) && ((address % 0x80) == 0))
                uint32_t* pDataByte = (uint32_t*)pDataToWrite;
                TerminalSend_Str_NL(''Writing half page'');
                // Half Page flash write is 128 bytes (and in multiple of 128-bytes)
                if (HAL_FLASHEx_HalfPageProgram(address, (uint32_t*) pDataByte) != HAL_OK)
                    TerminalSend_Str_Hexu32_NL(''HAL Flash Half Page Write Error: '',     HAL_FLASH_GetError());
And my linker file:
/* Initialized data sections goes into RAM, load LMA copy after code */
  .data :
    . = ALIGN(4);
    _sdata = .;        /* create a global symbol at data start */
    *(.data)           /* .data sections */
    *(.data*)          /* .data* sections */
    *(.RamFunc)        /* .RamFunc sections */
    . = ALIGN(4);
    _edata = .;        /* define a global symbol at data end */
  } >RAM AT> FLASH
Do you have any idea what could be wrong?
B.
Posted on December 10, 2016 at 05:32
I have the exact same problem.   I'm using Ramfunc properly.  I can avoid the PGAERR if I only write 8 bytes, e.g.
/* Write one half page directly with 32 different words */
while(count < 2) // was 32
But not very satisfactory. :)
Did you solve this problem?  I'm on an STM32L151xE.
Thanks,
G.
Nesrine M_O
Lead II
Posted on January 06, 2017 at 09:50
Could you please try to update the HAL_FLASHEx_HalfPageProgram() function as below:
/* Disable all IRQs */
__disable_irq();
while(count < 32)
*(__IO uint32_t*) ((uint32_t)(Address + (4 * count))) = *pBuffer;
pBuffer++;
count ++;
/* Wait for last operation to be completed */
status = FLASHRAM_WaitForLastOperation(FLASH_TIMEOUT_VALUE);
/* Enable IRQs */
__enable_irq();�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?
Please try with this update, and tell us about the result.
-Nesrine-
Ifmy suggestanswers your question, please mark it as correct.
Posted on January 06, 2017 at 19:51
You've added disable/enable_irq()... yes, I think that was one of my problems. Surprisingly in the voluminous but mostly useless boilerplate documentation, no mention or reminder about IRQs in any of the 3 stm32l1xx_hal_flash_*.c files.
I see you've maintained ridiculous coding convention of commenting on a properly named function. The useless verbosity is a hindrance to readability. A comment that says 'disallow interrupts so we don't cause a flash wait-state resulting in a PGAERR' would be ideal. And this original comment:
So one is not allowed to write 32 identical words? Where's the check for that? :)
Posted on January 27, 2017 at 11:29
The STM32L0 library does include interrupt handling:
__RAM_FUNC HAL_FLASHEx_HalfPageProgram(uint32_t Address, uint32_t *pBuffer)
uint32_t count;
HAL_StatusTypeDef status;
if(status == HAL_OK)
/* Proceed to program the new half page */
SET_BIT(FLASH->PECR, FLASH_PECR_FPRG);
SET_BIT(FLASH->PECR, FLASH_PECR_PROG);
count = 0U;
/* Write one half page,
Address doesn't need to be increased */
__disable_irq();
while(count < 16U)
*(__IO uint32_t*) Address = *pBuffer;
pBuffer++;
count++;
/* Enable IRQs */
__enable_irq();
/* If the write operation is completed, disable the PROG and FPRG bits */
CLEAR_BIT(FLASH->PECR, FLASH_PECR_PROG);
CLEAR_BIT(FLASH->PECR, FLASH_PECR_FPRG);
/* Return the write status */
return status;
Posted on January 27, 2017 at 16:45
Lucky you... the code I inherited does not have this.
* @file stm32l1xx_hal_flash_ramfunc.c
* @author MCD Application Team
* @version V1.1.3
* @date 04-March-2016
* @brief FLASH RAMFUNC driver.
