STM32H750 HAL_SPI driver function HAL_SPI_TransmitReceive(......) is called in my EXTI9_5_IRQHandler() interrupt function , It runs dead loop, and can't return.
Options
2021-06-04 12:04 AM
If the H7 HAL_SPI driver function HAL_SPI_TransmitReceive(......) is called in my main()
,It runs correctly, I can transmit and receive data correctly. But it is called in my EXTI9_5_IRQHandler() interrupt , It runs dead loop, and can't return.
Labels:
SPI
STM32Cube MCU Packages
STM32H7 Series
1 REPLY 1
Options
2021-06-04 8:14 AM
Calling blocking functions in interrupts is not ideal, but you can do it as long as the systick handler priority is higher (numerically lower) than the interrupt you're currently in.
