2022-10-26 9:01 AM
I need to transmit data over usb with minimum 1 Mb/s, I configured my mcu (stm32h732zg) as an audio device to get a large packet transfer.the function that transfer the data USBD_AUDIO_DataIn is empty. and USBD_CtlSendData i'm using cause the usb descriptor request failed.
How can i Achieve this speed?
2022-10-31 1:27 AM
Hello @MOhamed_Mehery,
I am not sure which MCU you use, do you want to refer to STM32H723?
Should be better to look for audio library
2022-10-31 1:27 AM
