STM32F4discovery high speed USB
‎2012-12-25 8:46 PM
hi
how can I get high speed USB interface to host a device on STM32F4discovery? would i have to remove component from the kit OR just add additional PHY? #high-speed-usb #usb-otg #cpen #otg_hs #highspeed #metoo-not-quite #host_ctrl_xfer #vbus- Labels:
USB
‎2012-12-26 7:14 AM
You'd need to add an external PHY, and address any pin conflicts.
Maybe look for some boards with the PHY already mounted.http://www.wvshare.com/column/STM32_DevelopmentBoard.htm#Open407I-C
‎2012-12-26 8:34 PM
‎2012-12-27 11:30 AM
The STM3240G-EVAL example projects have the following defines
USE_STDPERIPH_DRIVER,STM32F4XX,USE_STM324xG_EVAL,USE_USB_OTG_HS,USE_ULPI_PHYUp vote any posts that you find helpful, it shows what's working..
‎2012-12-27 8:12 PM
would i have to change 8MHz onboard crystal on stm32F4 discovery for high speed usb interface.
‎2012-12-28 8:01 AM
Why would you need to do that? Isn't the USB clock derived from the PLL VCO clock?Up vote any posts that you find helpful, it shows what's working..
‎2013-01-06 11:27 PM
hi, I am using USB3300 phy eval board, The CPEN pin didnt get High, why thats so? it continously low?
I just power up the board with 5 and 3.3 volts, but the CPEN pin is not getting high. (CPEN is the pin to enabled external VBUS) i didn't connect remaining pins to STM32F4. thanks- Mark as New
‎2013-01-09 4:53 AM
I think by setting USB_OTG_FS_CORE_ID = 1 will change USB to High Speed. Still I have not tried but I will post once I receive my Discovery kit.
‎2013-01-09 3:54 PM
Full Speed (FS) or High Speed (HS)? The issue here is the lack of a external PHY on the STM32F4-Discovery board.Up vote any posts that you find helpful, it shows what's working..
‎2013-01-13 10:17 PM
thanks for input. i am using USB3300 SMSC eval board. I am able to run high speed ULPI interface with STM32F4 Discovery using MSC high speed example for STM324xx boards. I have to change some PINs as PORTH and PORTI is not available in 100 qpf package in stm32f4discovery board.
the thing, I am not able to modify the code available in audio record play back example to HIGH SPEED, I have made the important changes , but what i am missing here? the FS OTG led is still blinking? even after i have changed the OTG_FS to OTG_HS and define ULPI etc...
